Spiegels vectra inklapbaar maken (OPGELOST)
De modules die u probeert te monteren, worden ze teruggezet?
Ik lees op engels forum dat het programmeren met opcom zal de modules bak.
België daar kom ik één keer per jaar door heen als ik naar Frankrijk op vakantie ga. Haha maar zal er over na denken. Bedankt alvast
Dit zijn de DDM en de PDM van de klapspiegels.
Kloppen de nummers?
Hi,
yesterday I received the new modules with upper specs JP and JN modules (have installed the folding mirrors). Using opcom to program my Vectra C 2004.
Somehow I succeed with programing the DDM. ( everything is working - folding,locking, unlocking and ...)
But I can't program the PDM. I try with my security code but received "condition not correct" and start security wait time.
What I have to do to reset/program the module?
You need the original security code from the car it came from.
Also, opcom is known to kill door modules - you're a brave man!
Opcom killed my PDM with folding mirrors
/! Warning !
When Woody says your Op-Com won't program them, he doesn't just mean it can't. He also means it will actually destroy them if you try.
So don't attempt to do it. Just read the variant codes as requested, and if they are the correct kind and need option activation, or if you must replace them, use a real Tech2.
This is important.
As mentioned already, DO NOT use opcom to program the DDM or PDM, it will fry the modules!
[EP / EQ / JN / JP = Prefacelift
JN / JP = facelift
JP / JN = fold unfold with switch/fold unfold with key
EP / EQ = fold unfold with switch/fold unfold with key
AP / AN = fold unfold with switch/fold with key
KP / KQ = fold unfold with switch
EP / AP = fold unfold with switch/fold unfold with key
bcm gives a signal to the DDM
ddm gives the signal pdm
Hi,
/! Warning !
This is important.
JN / JP = facelift
What I would do: take tis2000 or globaltis, check the wiring diagrams and prepare the cable loom exactly the same. You mentioned that some wiring was missing. As soon as cabling is correct and completed, I would mount the modules. But this modules must be reset from donour car or at least security code known. Then programming with tech2 and testing. It should work, were so many people doing the upgrades.
Wat ik zou doen: neem tis2000 of globaltis, controleer de elektrische schema's en maak de kabelset precies hetzelfde. U hebt gezegd dat sommige sm ontbrak. Zodra bekabeling correct is en compleet , IK bevestig de modules. Maar deze modules moeten herstellen vanaf donour auto of ten minste security code bekend. Vervolgens inlezen met tech2 en testen. Hij moet kunnen werken, zo veel mensen die de upgrades.
Heb het even vertaald maar ik denk dat ik beter het hele zooitje terug kan sturen want dit gaat mij een beetje te ver
