tijgetje57
Loopt hier de deur plat
1. locate the origonal breather elbow from the sump to the rocker cover on the front of the engine.
2. undo the two factory clamps and remove the elbow.
3. with the supplied elbow,measure and mark 40mm of straight tube on each end.
4. cut the tube so you are left with two 40mm straight connectors.
5. fit one of the tubes to the bottom of the breather box and use one of the supplied clamps to clamp it to the box.
6. fit the other connector to the rocker cover and use the origonal clamp to secure it to the cover.
7. slide the other origonal clip onto the black crank vent pipe,and fit the breather box to the top of the vent pipe.then use the clamp to secure it to the vent tube.
8. with the last supplied clamp,slide it over the connector on the rocker cover.then fit the breather into the tube and retain it with the clamp.
double check everything is tight and the job is done.
