Forumindex › Forums › Overige › Op-Com › OP-COM
- Dit onderwerp bevat 1,803 reacties, 2 deelnemers, en is laatst geüpdatet op 14 maart 2021om 10:08 door
bAstraJ2011.
28 september 2011 om 21:24 #17576818
Voor de liefhebbers
Hier een lijst(je) waar je het een en ander kan vinden en instellen. wel Engels maar met een beetje fantasie kom je er wel uit. Anders ff kopieren naar google translate. Alleen geeft ie dan voor disabled gehandicapt :jerryUEC (Underhood Electrical Center)
Under hood centre of electronics, it is sometimes called FZM (Front Zone Module). As the
name suggests is located in the engine compartment and is responsible for body electronics
in front of the car. To program the following functions:Crash Unlock Relay – opening of locks in an accident (only available in the Zafira-B)
Present / Not PresentDaytime Running Light – sets the version of the behaviour dimensions and low beam lamps
in relation to the position of the ignition key
Disabled / Variant 1 / Variant 2 / Variant 3 / Variant 4 / Variant 5AHL / AFL – Headlamp Levelling
Not Present / AHL / AFL Astra-H / AFL Zafira-BHeadlamp Washers – headlamp washer
Not Present / Present Astra-H / Present Zafira-BFog Lamp Front – Front fog lights
Present / Not PresentEngine Type – Engine type
Other / Z16XEP, Z16YNK / Z19DTxMTA (Easytronic) – robotized box Easytronic
Not Present, LUK / Magneti MarelliElectr. / Autom. Climate Control (ECC / SAC) – sets the availability of climate system
Present / Not PresentCheck Control – control of liquid levels in the washer tank and antifreeze
Present / Not PresentRain / Light Sensor – light and rain sensors
Present / Not PresentQuiescent Current Optimization – Optimization of quiescent current
Not Active / ActiveBody Type – Body Type
All Other / Zafira-BDriver Location – Location of driver
Left / RightRear Wiper – Rear window wiper
system
Present / Not PresentCDL witw Deadlock Functioality (Central Door Lock) – A central lock with a “dead” closing
doors
Present / Not PresentTail Lamp Coloration – sets the color of lamps taillights
5 Door Hatchback with Bright Tail Lamp / 5 Door Hatchback with Dark Tail Lamp / Other
Body TypeREC (Rear Electrical Center)
Rear center of electronics, it is sometimes called RZM (Rear Zone Module). Located in the
back left side of the vehicle and is responsible for body electronics, including the work of the
central locking and alarm system. To program the following functions:Body Type – body type
5 Door Hatchback / 3 Door Hatchback / StationWagon, Zafira / Convertible / AstravanDriver Location – the location of the driver
Left Hand Drive / Right Hand DriveDaytime Running Light – sets the version of the behaviour dimensions and low beam lamps
Disabled / Variant 1 / Variant 2 / Variant 3 / Variant 4 / Variant 5Rain / Ligth Sensor – rain sensor and light
Present / Not PresentWindows Comfort Closing – Closes glass while holding the keys on the key fob
Present / Not PresentSeat Heating Front – heated front seats
Present / Not PresentTransmission Type – type of transmission
All Other / Atom. transmissionSpeed Depended Locking – Automatic central lock when over 12 km/h
Present / Not PresentCDL with Deadlock Functionality (Central Door Lock) – central locking with dead lock doors
Present / Not PresentPEPS (Passive Entry Passive Start) – a system Open – Start
Present / Not PresentElectr. / Autom. Climate Control (ECC / SAC) – sets the availability of climate system
Present / Not PresentATWS / Country Code (Anti Theft Warning System) – the presence of anti-theft system
ATWS, oth. Count. / ATWS GB / Not PresentAlarm Horn / Alarm Siren – the type of audio signal
Theft Deterrent Horn / Alarm Siren / Not PresentU / S Module (Ultrasound) – presence of ultrasonic sensors
Present / Not PresentGlass Break Sensor Rear side Windows – Break sensors for the side rear windows
Present / Not PresentTrailer Reverse Light Monitoring – control lights reversing trailer
Present / Not PresentTrailer Fog Light Monitoring – monitoring the fog lights trailer
Present / Not PresentEmergency Brake Light Function – blinking stop lamps by the operation
ABS
Present / Not PresentTrunk Lamp – Lamp trunk
w.o. Switch
Not Active / ActiveRear Window – the presence of rear window
Body TypeCIM (Column Integration Module)
Control Center located electronically on the steering column. Serves as the gateway
between the CAN-Bus and also is responsible for staffing the immobilizer.Steering Whell Control – the presence of controls on the steering wheel
Present / Not PresentActive Select Switch – presence of the module gearshift on the steering wheel
Cruise Control – Cruise control availability of support functions
Present / Not PresentRear Wiper – availability features support the management of the rear wiper
Present / Not PresentWiper Stalk Location – location of the control switch wipers
Right Side / Left SideTransmission Type – type of transmission
MTA, manual / AT4 without CAN-bus SLM / AT with CAN-bus SLMCountry Code – Area Code
Great Britan / Other CountriesDIS (Display Information System)
Module Information Display. Located in the display case and performs certain functions
gateway between the CAN-Bus, features on-board computer and displays the information.Country Code – Area Code
Germany / G B / Spain / ………… / Other Countries or No RadioEHU – the type of entertainment centre
R10, CC20, CDC40 Opera, CD50 Phone, CD60MM, CD80MM / CD30, CD30mp3 / CD70
Navi, CD90 Navi / No RadioMobile Phone Portal – portal mobile phone
Present / Not PresentLanguage – Language
English / Spanish / Dutch / French / ………… /Unit – defines the system In-Use
Sl Units / Japanese Units / UK UnitsCorporation Type – Type car brand
Opel / GM Holden / GM Brazil / Vauxhall / Chevrolet / OPC / VXR / NoneBoard Computer – Computer literacy board
Present / Not PresentECC – climate control
Present / Not PresentCheck Control – control of the lamas lamps and headlamps
Present / Not PresentTPMS (Tire Pressure Monitoring System) – control of air pressure in tires
Present / Not PresentAlarm – Alarm and anti-theft system
Trailer Hitch – Trailer Hitch
Present / Not Present2 oktober 2011 om 11:42 #17576819Na het installeren en het gebruik van nederlands talig software doet mijn opcom niks meer. Volgens mij is iets met de firmware van het ding.
Wie kan mij vertellen hoe ik hier nieuwe firmware op krijg??
gr Jack
2 oktober 2011 om 11:59 #17576820Bij werkte engels goed ( en nog steeds ) ik gebruik sinds van de week nu wel de NL versie
Ik heb de 2 versies opgeslagen in verschillende mappen
Verder niets geinstaleerd werken allebei, afhankelijk welke snelkoppeling ik aanklikt op het bueaublad ( moet je ze daar wel even zetten natuurlijk)Gr Jan
9 oktober 2011 om 12:56 #17576664Daar ben ik weer ;)
Als ik met de Op-Com de dagtelerwaarde uitlees staat deze op 31524
Maar tot mijn verbazing geeft de teller in mijn dashbooard 31723 aanHoe kan dit ??
alweer alvast bedankt allemaal
Jan
9 oktober 2011 om 13:10 #17576740Klopt, deze waardes verschillen altijd een paar kilometer, dat is bij mij ook, geen idee waar het precies aan ligt maar het zou kunnen zijn dat de een teller de kilometers die je achteruit rijdt niet telt en de andere teller wel.
9 oktober 2011 om 13:32 #17576641Oke Mark, :thumb
Ben in ieder geval blij dat ik niet de enige ben ;)
Wat jij zegt zou kunnen.
Ik dacht eerst aan banden/velgen omtrek/omwentelingen.
Zojuist even gekeken :hmmz maar allebei de maten die er onder gezeten hebben ( 225/45/17 ) en nu de 225/40/18 zitten in de zelfde groep (2) dus dat kan het ook niet zijn.9 oktober 2011 om 18:14 #17576745Bij mij is dat ook het geval, geen idee eigenlijk wat daar de oorzaak van is.
9 oktober 2011 om 18:23 #17576734Misschien komen we er nog achter :hmmz
Voorlopig ga ik er maar van uit dat de vorige eigenaar een lange oprijlaan had en kon keren voor het huis :jerry9 oktober 2011 om 19:09 #17576735Kan je met zo’n toestelletje ook zelf je cd70navi afkoppelen of is dit enkel mogelijk bij een officiele garage?
9 oktober 2011 om 19:16 #17576804Ook dat is mogelijk.
Zelf nog nooit gedaan maar zie die optie wel staan.9 oktober 2011 om 19:26 #17576788Hallo iedereen,
Ik heb een tijd geleden de Op-Com 2010-08 software via de linkjes in dit topic opgehaald (de nl versie, de en versie en eentje met installer) maar die hebben een trojan horse (Trojan Generic25.SOC). Nou heb ik destijds een virtuele computer gebruikt om mijn auto uit te lezen waarbij ik dus geen risico op infectie loop maar nou ben ik eigenlijk nog steeds op zoek naar een versie die “schoon” is.
Heeft iemand nog een versie die bij hem/haar wel met glans door de virus-scanner komt?
9 oktober 2011 om 19:30 #17576746tja ik heb geen probleem met mijn 08-2010 versie..
9 oktober 2011 om 19:36 #17576817Zou je deze ergens voor mij online kunnen zetten?
9 oktober 2011 om 19:42 #17576822ik ozu megod niet weten hoe ik dat moet doen, en heb eigenlijk alleen nog geinstalleerde op de PC staan…
9 oktober 2011 om 19:49 #17576821Ik kan je ook mijn gmail adres per PM sturen zodat je het gewoon kunt mailen.
Dat hij geinstalleerd is, maakt niet uit: het programma werkt ook als je het gewoon naar mij zou opsturen. (Dus het mapje uit – waarschijnlijk – je Program Files)
9 oktober 2011 om 20:05 #17576319gebruik deze maar
ik heb alleen de driver geinstaleerd verder start ik op uit de map
http://www.mediafire.com/?79vezszjvrf8awf10 oktober 2011 om 18:38 #17576823Kan iemand me uitleggen hoe ik met mijn Op-Com een radio kan afmelden en weer aanmelden?
11 oktober 2011 om 06:34 #17576824ik heb het zelf nog niet geprobeerd maar je moet het zoeken in : deactiveren diefstalalarm en daarna een andere radio plaatsen en activeren diefstalalarm.
11 oktober 2011 om 15:44 #17576825Getsiederrie…Heb ik een verloopkabel voor op de oude 10pin stekker. Pakt ie um nie. :wtf
Zal wel in die kabel zitten want de oude uitleeskast op het werk (soort van tech1) pakt hem wel netjes…..
Toch maar ff 1 bij smeets bestellen denk ik dan maar…
11 oktober 2011 om 15:45 #1757682611 oktober 2011 om 17:59 #17576827fearless: ik heb dat verloop kabeltje ook bij smeets gekocht, ik kon toen
mijn astra uitlezen met obd1, werkt goed moet ik zeggen, alleen kan ik minder dingen doen
als bij mijn vectra b1.gr, jac.
11 oktober 2011 om 18:08 #17576828Haal ik m daar ook ff
12 oktober 2011 om 15:22 #17576829Heb net mijn OP-Com setje aangekregen, helaas was de bijgeleverde cd gebroken :( Had dan op het internet gezocht en gevonden maar ik kan blijkbaar de drivers niet installeren ….. Staat een geel uitroeptekentje bij, en als ik naar de map drivers ga, dan zegt hij wel in een DOS venstertje dat hij de drivers installeerd maar het gele uitroeptekentje gaat niet weg …. Wat doe ik verkeerd????
12 oktober 2011 om 17:45 #17576830Tommy,
Misschien heb je het zoal gedaan hoor
Naar apparaatbeheer/op de poort met uitroepteken gaan staan/rechtermuisknop/stuurprogramma bijwerken/niet automatisch maar op de computer zoeken/bladeren naar de map met drivers en die aanwijzen.Zo deed ie het bij mij wel
Gr Jan
12 oktober 2011 om 17:52 #17576831neen, dat lukt niet. In de map drivers staat enkel het .exe bestand en geen drivers ….
