Astra L: no welcome and bye-bye light when lock/ unlock car.
Forumindex Forums Modellen Astra Astra L: no welcome and bye-bye light when lock/ unlock car.
  • #18497203
    yunfeng xia
      20 December 2022
      I have the Opel Astra PHEV.
      Normally when I unlock the car, the daytime running light will be activated. For locking, the yellow light will flash.
      However, it doesn’t work since yesterday, specifically, when I lock the car, I can only hear the locked sound but no light.
      Does anyone know how to fix it? Any experience from previous Astra could be helpful as well.
      Thanks,
      Yunfeng
      #18497547
      liviu2004
        6 April 2014
        Ga maar naar de dealer, auto is nog in garantie periode.
        #18515237
        AstraBelgica
          7 March 2023
          I have the same problem, worked fine and suddenly stopped. Tried everything without success. Did you get a fix already?
          #18525523
          Styloh_
            4 May 2023
            Hetzelfde probleem hier, iemand een oplossing?
            #18525590
            liviu2004
              6 April 2014
              Nee, die boven zijn bots, geen echte.
              #18525601
              yunfeng xia
                20 December 2022
                Yes, I went to garage and they replace one model. It works right now but I don’t know how long it will last.
                #18525603
                yunfeng xia
                  20 December 2022
                  It happened after I open and close the front cover of engine. I went to garage and garage said it is because of the poor connection with some cable. I recommend u to go to garage for checking this issue.
                  #18525663
                  AstraBelgica
                    7 March 2023
                    Ik ben geen bot hoor! Nog geen oplossing gevonden, maar ben ook nog niet naar de garage geweest. Bij mij is het probleem ongeveer ontstaan toen ik een extra profiel heb aangemaakt.
                    #18526077
                    Styloh_
                      4 May 2023
                      Ik had het plots zonder iets zelf te doen, van de ene dag op de andere was het kapot.
