lol
het is een engelse hill climber, ding is echt ziekelijk, zoveel detail werk.
speclist:
Nova 985cc Turbo - Approx. 160 BHP
Bodyshell
Lightweight shell to ‘Modified Production’ hillclimb/sprint regulations
Full BTEC Racing roll cage with multipoints, X diagonals, X door bars, harness bar
Quick release bumpers
Modified inner wings
Steel front wings
Aluminium skinned doors
Fabricated front crossmember
Alloy slam panel
Fibreglass bonnet
Fibreglass tailgate aluminium Gurney flap
Alloy rear lamp blanks
Alloy headlamp blanks
Single wiper linkage
Polycarbonate windows, including windscreen
Engine
985cc Vauxhall OHC
Sleeved down from a 1200cc block
7.5 to 1 Compression Ratio
Metro van pistons
1600 cylinder head and camshaft
Engine lowered 1.5 inches and moved back and to the left
OMEX 600 ECU & aircraft spec. engine loom
Turbosmart boost controller
Anti-lag system
Vernier camshaft pulley
Remote oil filter
Total loss electrics (no alternator)
Solid engine mounts
IHI hybrid turbo
PACE PRODUCTS alloy intercooler with 3” pipes
PACE PRODUCTS alloy radiator
Alloy water swirl pot
Alloy water header tank
Alloy oil breather tank
Silicone coolant and boost hoses
2.5” stainless steel side exit exhaust system
Transmission
F10 five speed gearbox with 4.5 final drive
Quaife ATB LSD
Hydraulic clutch with AP master cylinder
Fabricated internal rose jointed gear linkage
Interior
ELLIOT rev counter
RACETECH boost gauge
Water and oil pressure gauges
FIA approved ignition cut offs
Push button starter
Suede steering wheel on SPA DESIGN quick release boss
CORBEAU REVOLUTION side-mounted seat
WILLANS 5 point harness
Lightweight steering column
VARLEY RED TOP 15 lightweight battery
Alloy battery tray
Lightweight wiring loom and switch panel
Fuel System
Alloy foam filled fuel tank underneath floor
FSE high pressuere fuel pump
Facet Red Top lifter pump
Alloy swirl pot
Aeroquipped throughout
Brakes
247mm 4 pot WILWOOD front brakes with EBC Green Stuff pads
Standard rear drums
Floor mounted pedal box with AP master cylinders, bias adjustable
Pressure limiting valve to rear brakes, adjustable
Handbrake removed
Suspension
LEDA 2.5” front dampers with alloy top mounts, 375lb springs
SPAX coilover rear dampers 1.9“, 120lb springs
Rose jointed adjustable track control arms
Rose jointed tie bars
T45 steel tubular rose jointed front and rear anti-roll bars. Rear is remote adjustable.
Wheels and Tyres
4 x Compomotive MO 7” x 15”alloys with AVON A15 soft compound slicks
4 x Revolution RFX 6” x 13” with AVON cut wets
Other
All unstressed bolts replaced with aluminium lightweight fasteners
MSA logbook for hillclimb and sprint
Total weight 595kg
