DB69 - Portuguese Corsa 2.0 16V Turbo
Originally posted by bbg_gendt
Maybe add a stiffening bridge in the motorbay? ( For cornering )
http://www.kerni.nl/fotos/democars/corsa/corsa_b_nieuw_groot.jpg
The car has the weld-in rollcage going to the top of the front suspension, has well has other 9 points (11 in total),
and the substitute of bar you talk about is behind the fire shield under the scuttle.
I think that it corners ok for a corsa...
in that note, here is a picture of the Track début back in the day:
Originally posted by Piele
GD!!!! :wtf
You robbed a bank, or what??!!!
No, just worked a lot to earn it since the project started in 2002. :agent
origineel gepost door Akeemking
Pic shows only outside of the car here :) . Do you have pictures from inside?
It's better if the bar is placed on the front suspension points, as also on the back, connected to the roll cage. When you corner most force comes on the front suspension points.
( Blue one you have, green should be added, with reinforcement, yellow )
( green linked to blue I also have but not like you draw... and yellow is reinforced )
Only thing I know for sure is from my old Corsa experience, which had that bar you talk, and this one now without the bar but full welded with rollcage. No comparison possible... I only wished the old corsa handled 25% like this one now.
Yes, I have some pictures of the after painted...
I must point out about the rollcage that it is FIA approved and build specific for Corsa B rally cars by British company Safety Devices.
But, maybe you are right... just fitting one and trying it can say for sure if is needed or not in this case.
I cannot see it clear from the picture how you made the replacement for the green line actually:) . But the rest :thumbup , nice work.
Okay, got it. But still would prefer the " bridge ". As when cornering, both coil points, tend to come inside ( exaggerated )
Keep up the good work king:
Look who's taking.... i know a guy named BBG_gendt who used 1mm sheet metal for floar boards without anny strengthening or ridges, then crapped some molded lava on it what he called a weld. So don't act if u are the stiffnes guru... Chassis is perfect!
Annyway back to the Corsa ! Like your project very much, u got some nice hardware in it!
origineel gepost door jblfreak
where did you get the blinkers at te front i'm stille looking fot them
very nice corsa i like it
ik dacht dat je die bij de morrette koplampen kreeg omdat daar geen knipperlicht inzit als ik het goed hebt :hmmz
Yes Dennis, the blinkers are from Morette kit...
maybe you can contact them and they will sell them separated from the kit.
@ Akeemking :
i got them 2e hand and the where not on the set but still on the corsa because the front bumper
but after the post i got an u2u of someone and he has them for me
but thanks after all
