Beste heren dit zijn de foutcode’s die Turbo Dreams uit mijn auto heeft uitgelezen.
Nu moet ik er nog achter komen wat ze betekenen en hoe te verhelpen.
Wie kan mij daarbij helpen?
Alvast bedankt
@Turbo-Dreams wrote:
number of fault codes: 4
P1120 – Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
(52) – Not present
P1122 – Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
(52) – Not present
P1895 – Limp home – Limited Performance
(54) – Not present
P0500 – Vehicle Speed Signal Range/Performance
(74) – Not present
Number of stored fault codes: 3
C0242 – Engine Torque Request Signal Range/Performance
(71) – Not present
C0237 – Accelerator Pedal Position Sensor Incorrect Signal
(71) – Not present
C0800 – System Voltage Low Voltage
(03) – Not present
Number of stored fault codes: 1
U2100 – No Communication with CAN-Bus (Low Speed)
(00) – Not present
Number of stored fault codes: 2
B3888 – Right Trailer Turn Signal Circuit Malfunction
(00) – Present
U2139 – CAN-Bus No Communication with CIM (Steering Column Module)
(00) – Not present
