<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>Hello,</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>I may have something again that you know what it is</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>The other day I had a flat tire on the right front, it turned out to be only the valve.</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>But I had to use my spare. </span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>Wheels are 245/17 and the reserve 195/15 according to me</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>When the reserve was put on I heard a bit of a knocking sound was fortunately not that far from home about 25 km </span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>But when I made a long turning right I suddenly hear a sound as if you are working with a circular saw just as if the brake disc against the metal on the rim of the spare tire. https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>So I thought of putting that original tape back asap. </span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>When it was there once it was beating away but when I get to exactly those same bends I still hear that metal grinding sound seems like something is coming up and it has happened since I changed that tire.</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>It is only with a long turning right and again not always depends on the speed and the amount and speed of steering.</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>thanks</span></span>
<span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>alexsunny</span></span>
