How To Change Navi CD500- DVD 800 Theme’s
Forumindex Forums Modellen Insignia How To Change Navi CD500- DVD 800 Theme’s
23 berichten aan het bekijken - 1 tot 23 (van in totaal 23)
  • #17274308
    Timothydevisser
      26 June 2014
      Met dank aan personen van de opel club polen :)
      Hier een uitleg hoe je een thema kan veranderen van je dvd800 navi of simpelweg zorgen dat je een 3d functie op je navigatie krijg.
      Windows Requirements
      http://www.imgburn.com/index.php?act=download&amp” onclick=”window.open(this.href);return false; (Free CD Burning software for Windows)
      http://www.rarlab.com/download.htm” onclick=”window.open(this.href);return false; WinRAR (Shareware software for extracting .rar files, this software is similar -but better- than WinZip/Zip)
      A little bit of IT expertise (depending on what you’re wanting to achieve!)
      Time & Patience
      Mac Requirements
      A CD Writing application (I use Toast, but this is not free)
      Time & Patience
      Method
      You need to download a modified version of the GM Update Disc as linked below. Once downloaded you need to burn the contents to a CD (or copy the files to a USB drive). Depending on the file you choose, will depend on the outcome. Some themes include the CD500 to DVD800 patch and as a result add 3D navigation views, some do not include the patch (Infinity MY2009/MY2010 does not for example). Whichever update you choose may or may not erase your current maps. In many cases, the maps tend to remain in the memory of the CD500 (MY2009/MY2010) despite the warning suggesting otherwise (this cannot be guaranteed). Retaining the maps on MY2011+ is a bit more miss than hit, with more users reporting the need to reload the maps.
      Note:
      For MY2011 users upgrading to the DVD800 firmware, CD500 map updates are no longer recognised. For MY2009-10 you can still use the CD500 maps.
      It is possible to downgrade back to the original CD500 state if you wish.
      Note: Everything you do – you do at your own risk . If in doubt do not attempt this. It is almost guaranteed that carrying out this procedure will void any warranty on the affected items. Due to the nature of the Vauxhall radio setup, a fix could cost in excess of 500.00 euro
      Upgrading CD500 to DVD800
      – introduces 3D Maps and Tours functionality to CD500 users.
      If you want to keep the original themes, but just patch up to a DVD800, and get the 3D Navi view, and Tours function, then this is all you need. Download the file and then skip to the ‘Performing the Upgrade’ section towards the bottom.
      Download
      https://mega.co.nz/#!8dJX2ZYC!W_EL9X90QqOGYkmo3PUX-RYdkcwcynANvyKs6mVrJ54″ onclick=”window.open(this.href);return false; “Original” Theme – MY2009/MY2010 (CD500 to DVD800 patch only)
      If you want to change the appearance, then download a theme from below and read on.
      Applying a Theme to your CD500/DVD800
      – see images below, some of these themes may also add the 3D Maps and Tours functionality.
      Downloads
      https://mega.co.nz/#!wEIUQDoS!dP2B1OEIdD2dAbGyLNav6xdate57fBLO6tZTiLcFGfU” onclick=”window.open(this.href);return false; “Carbon” Theme – MY2009/MY2010
      https://mega.co.nz/#!9MpzkSDD!TNxpvTvKu0tXQz4a74neby1ww-74kZ2fOaGUvq-TiZ0″ onclick=”window.open(this.href);return false; “Carbon” Theme – MY2011
      https://mega.co.nz/#!IJ5AhJqY!-OBxq8vQ04pjkumDx_LECBFItxWDFPSYm4AcuzucO74″ onclick=”window.open(this.href);return false; “Adam” Theme – MY2009/MY2010
      https://mega.co.nz/#!pVIwFLhI!G1YdaG3djMbMQ6jB2yCe5BqxtzPIdPAwIsorHxAJeU0″ onclick=”window.open(this.href);return false; “Adam” Theme – MY2011
      https://mega.co.nz/#!tBw2nIDb!E1iwDoB6McnlE1LLXwcil6QA8BbJLUmJ92jpKosGfik” onclick=”window.open(this.href);return false; “Apofigey v2” Theme – MY2009/MY2010
      https://mega.co.nz/#!kNITHJgD!FDbuDfB83MwYiQDYm6hOKjxJ3Ck6lvkDtkDDZlj2N4U” onclick=”window.open(this.href);return false; “Apofigey v2” Theme – MY2011
      https://mega.co.nz/#!AFxUECbY!uCVG3cWz29Z6cgPT2MvD1m3EfUjarzVhgt97VBp36EQ” onclick=”window.open(this.href);return false; Engine1992’s “Red” Theme – MY2009/MY2010
      https://mega.co.nz/#!MRhk2RLZ!950pWTsduR1XLGZ-HU1TdyOzhpaoPSPuahixgmP_iSU” onclick=”window.open(this.href);return false; Engine1992’s “Red” Theme – MY2011
      https://mega.co.nz/#!xUwVxAra!x8Uox1RBh1CPkudTjfFmtebieIbatknY3iqC2egybKc” onclick=”window.open(this.href);return false; Engine1992’s “Infinity” Theme – MY2009/MY2010
      https://mega.co.nz/#!IJ5AhJqY!-OBxq8vQ04pjkumDx_LECBFItxWDFPSYm4AcuzucO74″ onclick=”window.open(this.href);return false; Engine1992’s “Infinity” Theme – MY2011
      Download one of the above files, they range from 150MB to 300MB. After the download has finished, you should have a .rar file (similar to a .zip), this needs to be extracted using one of many free tools available online. My recommendation would be WinRAR on Windows, or Keka on Mac.
      Once extracted, you have two options; burn the ’theme’ as is, or attempt to modify the theme yourself. Modifying the theme requires time, patience and knowledge. I’ll briefly touch upon modifying later, for now, I’ll explain how you simply prepare a theme for install.
      After extracting the download, you will either have a folder called /dnl/, or a folder of the filename, and inside that /dnl/.
      If you’re only interested in using one of the pre-made themes, then you simply need to burn this /dnl/ folder (and its contents) to a CD. It is recommended that you burn the disc at a slower than normal speed, 4x for example. In days of yore, older drives, with crappy lasers used to be very fussy at reading discs, and one trick to combat this, was to burn at a slow speed. MY2011+ users also have the option of using a USB drive, this must be formatted as FAT32.
      With your freshly prepared update disc/USB drive at the ready, head out to the car and switch on the ignition (I had the engine running). Turn the radio on, so that you can see whats on screen and hear the music. Ensure you’re on a station you enjoy, and that the volume is at a nice level. When you’re happy insert the USB drive, or CD and follow the onscreen prompts. Once you confirm the update two or three times, it will begin at which point you’re pretty much stuck with whatever volume/station you have on, so make sure you are happy as the process takes roughly 20-30 minutes.
      During the update, there are certain percentages where the update appears to have stalled. Fear not, be patient. As you’re erasing and writing the flash, any interruption could be fatal to the stereo. So just leave it well alone.
      After the update, the radio will automatically turn off, and back on, then after a minute or two, it will go off again, and turn back on to the ‘standby screen’. At this point you can turn it on again. After a few more minutes, the time and date should set. After this, you’re free to explore.
      Note Some MY2011-> users appear to have experienced issues if the car is fitted with the original Bluetooth module, and losing the ability to use your steering wheel control. I am unable to decipher the foreign language on this one, and as I am MY2009, I did not experience this issue. What I would say, is that if you’re MY2011+ and have Bluetooth, do your own digging…
      If you’re wanting to customise a theme, or make your own. You’ll need the uli GM Files Extractor Ver 2.8.5, time, patience and photo editing skills… I suggest reading this, which should provide enough information for those wanting to go that extra step.
      …and, the all important “Panic Button”, or should I say, the downloads you need to reset everything to standard should you need to;
      https://mega.co.nz/#!FIhxXTQT!0qasPLW8nmNy6H_hEf1Sq4J214HXq_4lej6BGB2ZHBQ” onclick=”window.open(this.href);return false; MY2009/MY2010 – CD ‘SOFTWARE UPDATE’, V-2010/1.0 (13343362)
      https://mega.co.nz/#!VRZ1BD6L!u4h7u6UWipJK7fXjJRK4nmbPmxkWHHiRom0tXx-w-lc” onclick=”window.open(this.href);return false; MY2011 – CD ‘SOFTWARE UPDATE’, V-2011/1.0 (22795977)
      #18342816
      kvangulik
        11 July 2009
        Werkt dit ook op een CD500 in een Astra J van 2010? Ik heb het geprobeerd naar als ik de USB erin doe dan ziet ie de USB als niet ondersteunend apparaat.
        #18342931
        Opel fanaat
          6 February 2017
          Hallo ,kvangulik heb het met versie my2011 geprobeerd en het werkt,het dnl bestandje is van belang.
          Groet Klaas
          #18346982
          TC Orhan Cakir
            8 August 2017
            Ik ben in het bezit van Opel Astra J 1.4 Turbo oktober 2010.
            Met op de 10 de plaats een B.
            Welke van de twee CD500- DVD 800 My10 of MY11 moet ik downloaden…..?
            M.v.g
            O.Cakir
            #18347025
            Opel fanaat
              6 February 2017
              TC Orhan Cakir , hallo volgens mij is het my2010 maar als je de oude navi,cd nog hebt staat het daar wel op.
              Anders gewoon proberen met een usb stick , heb ik ook gedaan je kunt altijd weer terug met die update cd my2010 /cd my2011.
              met vriendelijke groet. Klaas
              #18347463
              _Simon
                22 August 2017
                Een korte vraag, ik ben nieuw hier en heb sinds kort een astra J MY2011. Met een CD500 als navigatie.
                Graag zou ik de 3D beeldweergave willen gebruiken. Alleen is het mij niet helemaal duidelijk welk bestand ik nodig heb om alleen de “upgrade” uit te voeren.
                Het veranderen van thema hoeft van mij niet zo nodig.
                Als ik naar de te downloaden bestanden kijk staat er alleen een stock thema upgrade van de MY2009/2010 niet voor de MY2011.
                Of is het voor de MY2011 hetzelfde bestand?
                Gr,
                Simon
                #18347506
                Opel fanaat
                  6 February 2017
                  _Simon ,als jou Astra van 2011 is met de B op de 10 e plaats heb je een dvd 800 en kun je bv. red theme nemen van Insignia Polen .Ps je kunt dan ook een navi dvd van heel Europa er in doen alleen niet install. maar gebruiken tijdens de rit.Heb een op marktplaats gevonden voor €70 van 2015 .
                  Groet Klaas
                  #18347517
                  _Simon
                    22 August 2017
                    Bedankt voor je reactie Klaas ;) ik zal het red thema proberen. En een dvd voor de kaarten heb ik gelukkig.
                    Maar als ik het goed begrijp heeft het red thema ook de upgrade van CD500 naar DVD800? Of is het alleen een thema?
                    #18347962
                    jonglar
                      7 September 2017
                      Hi, I have updated a DVD 800 MY11 (on Opel Meriva) successfully.
                      How can I uninstall the update?
                      :help: :help: :help:
                      #18348000
                      Opel fanaat
                        6 February 2017
                        _Simon ,ik heb een dvd van 2015 (Europa) en daar zat de upgrade op.
                        Groet Klaas
                        #18348001
                        Opel fanaat
                          6 February 2017
                          Hello jonglar ,https://mega.co.nz/#!VRZ1BD6L!u4h7u6UWipJK7fXjJRK4nmbPmxkWHHiRom0tXx-w-lc also picture from cd my 2011 to turn back to original.
                          greets Klaas
                          #18348681
                          Kristof Nysen
                            29 September 2017
                            Goedemorgen allemaal,
                            Is deze update veilig? Bestaat er de kans dat het systeem onherstelbaar wordt beschadigd?
                            Alvast bedankt!
                            Kristof
                            #18355630
                            Rick-Opel
                              30 April 2015
                              Welke ben ik benodigd voor mijn Astra J uit 2009, er zit een CD500 Navi in en wil dus graag ook 3D mappen.
                              Welke link moet ik daarvoor hebben?
                              Dank!
                              #18356741
                              pingudew
                                2 June 2018
                                Will this work with Opel Insignia 2010? Do i get the maps?
                                #18359612
                                Vangelder
                                  18 August 2017
                                  Ik heb die cd ook maar  ik kan dat niet doen andere achtergrond
                                  #18359613
                                  Vangelder
                                    18 August 2017
                                    #18363925
                                    HenryK
                                      14 February 2019
                                      Zou iemand mij de goede link willen geven voor thema adam voor dvd800 insignia bj 2011..en uitleg willen geven hoe ik het installeer in de auto..mn engels is niet zo best ;-)
                                      #18363939
                                      HenryK
                                        14 February 2019
                                        het is gelukt20190215_171753
                                        #18363948
                                        Vangelder
                                          18 August 2017
                                          Hoe heb jij het gedaan dan moet je op een bestandje zetten of zo  hoor het graag van je
                                          #18372256
                                          Цветелин Йорданов
                                            7 February 2020
                                            so my insignia 2009 NAVI 800 is broken thanks to this post! can someone tell me how i can fix it ? it’s stuck on downloader ver. apr 3 2009 source: flash status 1.looking for baatch file path: /nandi/dnl/bin/system/adit/arge09me Please insert correct  Download medium ! PLEASE HELP
                                            #18372304
                                            Insigniauser
                                              29 November 2014
                                              @ Цветелин Йорданов
                                              Have you carefully read the full article? You must select the right version (MY = model year of car) of the update/ patch! Otherwise your system will hang.
                                              Important is to look at the 10th digit of your Vehicle Identification Number = VIN (9, A or B depending on MY), not the date on your papers. If digit is 9 or A = MY 2008-2010, if B MY = 2011- 2013. DO NOT USE MY11 PATCH ON OLDER (e.g. MY 09) SYSTEMS!!!!
                                              Changing 2D view to 3D view on CD500 only applies for MY11 systems with provided patch for MY11. Updates do not have any newer maps, only system patch/ system update. For maps you have to go to reseller or dealer.
                                              Btw, DVD800 in MY09, is that correct?  Do you have the original CD/DVD of your system which was delevered with the car? You can always downgrade/ revert to stock version of the system to factory settings using this.
                                              Don’t forget to leave he car running during update/ downgrade.
                                              #18402132
                                              tijne
                                                25 January 2005
                                                Beste,
                                                is er iemand die de software nog heeft voor de my2011?
                                                alle download links werken niet meer, en ik heb net een cd500 in mijn auto gezet maar zoek nu dus de update.
                                                wie o wie kan mij hier aan helpen?
                                                gr MArtijn
                                                #18554793
                                                PVB
                                                  25 April 2006
                                                  Iemand toevallig een link van de CD500 naar DVD800 update met originele theme voor MY 2011 Astra J?
