Dismantle side window Astra G ?.
Forumindex Forums Modellen Astra Dismantle side window Astra G ?.
  • #18420915
    jackyjoy123
      25 May 2021
      <span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>Hello,</span></span>
      <span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>I want to remove the side rear windows from my 2001 astra. </span><span style=”vertical-align: inherit;”>This is because I want to cover them with foil. </span><span style=”vertical-align: inherit;”>I don’t actually see any other solution to do it properly. </span><span style=”vertical-align: inherit;”>Now this afternoon I removed the upholstery to see how it is mounted. </span><span style=”vertical-align: inherit;”>Now I think the window is clamped in a bar with a rubber mat. </span><span style=”vertical-align: inherit;”>Do I just have to pull the window out with some force or is it different? https://krogerfeedback.nl https://talktosonic.onl https://talktowendys.vip https://whataburgersurvey.onl</span></span&gt;
      <span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>thanks</span></span>
      <span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>jackyjoy</span></span>
