Diagnostisch rapport vol met fouten?
Forumindex Forums Modellen Astra Diagnostisch rapport vol met fouten?
  • #17226859
    SjoerdB
      30 January 2012
      Ik heb gisteren even Op-Com aangesloten op m’n auto en het werkt allemaal prima. Ik heb echter een diagnostisch rapport laten maken door Op-Com en dit kwam er uit:
      DIAGNOSTIC REPORT:
      OP-COM 100219a
      hkj
      **********************ECU ID STARTS**********************
      Source Address: CIM
      Source Address: 0x00000245
      Identifier: 0x010A
      VIN: W0L0AHL0855229340
      System name: VALEO A3300 CIM
      Hardware number:13198908
      Part Number:13198908
      Software version number: M:70.49 S:01.00A
      System description: VALEO0400
      Hardware key number: 94GDMQ
      Programming Date: FFFFFFFF
      Alpha code: ÿÿÿ
      Manufacturing date: 20050607
      Code Index and version: ÿÿÿ ÿÿ
      Number of stored fault codes: 9
      B3055 - Transponder Key Problem
      (00) - Not present
      B3925 - Wrong Environment Identifier Received IPC (Instrument)
      (00) - Not present
      B3929 - Wrong Environment Identifier Received REC (Rear Electrical Centre)
      (00) - Not present
      B3977 - Wrong Environment Identifier Received UEC (Underhood Electrical Centre)
      (00) - Not present
      U2113 - CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag)
      (00) - Not present
      U2116 - CAN-Bus No Communication with IPC (Instrument)
      (00) - Not present
      U2117 - CAN-Bus No Communication with DIS (Display)
      (00) - Not present
      U2140 - CAN-Bus No Communication with UEC (Underhood Electrical Centre)
      (00) - Not present
      U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
      (00) - Not present
      **********************ECU ID ENDS**********************
      Source Address: ECM
      Source Address: 0x000007E0
      Identifier: 0x072A
      System name: Z19DTJ
      Hardware number:81012122
      Part Number:55198054
      Software version number: VTSMS060_S
      Hardware manufacturer number: 0281012122
      System description: 1037371870P319_O83
      System description: BOSCH0100
      Type approval number: B05029
      Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
      System description: 0x00015018
      Alpha code: AL
      Software version: O83JTD74
      ECU variant coding: 0x000010C5
      Number of stored fault codes: 3
      P0070 -
      (71) - Not present
      P0650 -
      (70) - Not present
      P1614 -
      (50) - Not present
      Source Address: ABS/TC/ESP
      Source Address: 0x00000243
      Identifier: 0x0494
      System name: ESP MK60
      Hardware number:16039000
      Part Number:13213610
      Software version number: D4_REL00354
      System description: TEVES0300
      Programming Date: 00000000
      Alpha code:
      Manufacturing date: 00000000
      ECU variant coding: 0x0000E681
      No fault codes stored.
      Source Address: EHPS
      Source Address: 0x00000244
      Identifier: 0x0203
      System name: EHPS EP2 ZFLS
      Part Number:13192897
      Software version number: 7625379109 P522
      System description: ZFLS 0011
      Programming Date: 20202020
      Alpha code: JV
      Code Index and version: 001 01
      Source Address: IPC
      Source Address: 0x00000255
      Identifier: 0x1001
      System name: BCM/KOMBI-A3300
      Part Number:13216684
      Software version number: 4.405 11/04
      System description: SIEM 0400
      Hardware key number: 0000000000
      Alpha code: PF
      Code Index and version: 001 05
      P0500 - Wheel Speed Sensor Circuit Range/Performance
      (71) - Not present
      P0654 - Engine Speed Signal Range/Performance
      (71) - Not present
      P0550 - Mileage Circuit Range/Performance
      (71) - Not present
      P0460 - Fuel Level Sensor Circuit Range/Performance
      (71) - Not present
      U2113 - CAN-Bus No Communication with SDM (Airbag)
      (00) - Not present
      (00) - Not present
      (00) - Not present
      (00) - Not present
      U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
      (00) - Not present
      Source Address: AIRBAG SDM
      Source Address: 0x00000257
      Identifier: 0x0204
      VIN: W0L0AHL0875037787
      System name: MRSZ-Temic
      Part Number:13188854
      Software version number: A3300RG3 V 3.1.0
      Alpha code: GS
      Manufacturing date: 20060913
      (00) - Not present
      (00) - Not present
      (00) - Not present
      Source Address: UEC
      Source Address: 0x00000250
      Identifier: 0x0106
      System name: FZM INTEDIS
      Part Number:13206754
      Software version number: FZM 8.16
      Alpha code: HB
      Manufacturing date: 20050603
      Number of stored fault codes: 5
      B1375 - Switched System Voltage (Ignition ON) Not Plausible with CAN Signal
      (5A) - Not present
      B2699 - Right Low Beam Circuit Open
      (05) - Not present
      (00) - Not present
      (00) - Not present
      U2141 - ????
      (00) - Not present
      Source Address: REC
      Source Address: 0x00000251
      Identifier: 0x0108
      System name: RZM INTEDIS
      Part Number:13206762
      Software version number: RZM 8.12/
      Alpha code: HK
      Manufacturing date: 20050601
      (5A) - Not present
      (00) - Not present
      (00) - Not present
      (00) - Not present
      (00) - Not present
      Source Address: ECC
      Source Address: 0x00000248
      Identifier: 0x0201
      System name: ECC A3300
      Hardware number:24452694
      Part Number:13122963
      Software version number: 0AL00/29C68
      System description: PREH 0000
      Alpha code: 000
      Manufacturing date: 20050525
      Code Index and version: 003 02
      Source Address: EHU
      Source Address: 0x00000241
      Identifier: 0x0401
      System name: CD 70 Navi
      Hardware number:13187941
      Part Number:13188465
      Software version number: C0088/R4904/N0091
      Alpha code: LG
      Manufacturing date: 20050524
      Code Index and version: 002 03
      Audio Index and version: 023 04
      Source Address: DIS
      Source Address: 0x00000246
      Identifier: 0x1201
      System name: CID/GID Delta
      Hardware number:13111163
      Part Number:13111163
      Software version number: GD59-/00050
      Alpha code: KP
      Code Index and version: 007 01
      (00) - Not present
      (00) - Not present
      (00) - Not present
      Wat is er allemaal mis mee? Ik snap er allemaal niets van. :thumbup
      #17739910
      CarloAstra
        18 December 2006
        Alle codes staan op niet aanwezig. De foutcodes wissen en kijken of er toch nog eentje terug komt.
        #17739911
        SjoerdB
          30 January 2012
          In het eerste bericht stond niet het gehele log, my bad. Ik heb toevallig gisteren alles verwijderd, moet eens kijken of ik vanavond een nieuwe log kan maken. :)
