Forumindex › Forums › Overige › Restauratie, verbouwingen en styling › DB69 – Portuguese Corsa 2.0 16V Turbo
- Dit onderwerp bevat 48 reacties, 20 deelnemers, en is laatst geüpdatet op 1 oktober 2009om 21:41 door
Akeemking.
21 september 2009 om 22:14 #17525308
1 January 1970niceeeee:D:D:D
21 september 2009 om 22:43 #17525309Originally posted by bbg_gendt
Maybe add a stiffening bridge in the motorbay? ( For cornering )http://www.kerni.nl/fotos/democars/corsa/corsa_b_nieuw_groot.jpg
The car has the weld-in rollcage going to the top of the front suspension, has well has other 9 points (11 in total),
and the substitute of bar you talk about is behind the fire shield under the scuttle.I think that it corners ok for a corsa…
in that note, here is a picture of the Track début back in the day:
Originally posted by Piele
GD!!!! :wtfYou robbed a bank, or what??!!!
No, just worked a lot to earn it since the project started in 2002. :agent
21 september 2009 om 23:01 #17525310First trackday test after build.
One lap was recorded. Track was a bit wet…
http://www.youtube.com/watch?v=mE305NKgBSw22 september 2009 om 08:52 #17525311origineel gepost door Akeemking
Pic shows only outside of the car here :) . Do you have pictures from inside?
It’s better if the bar is placed on the front suspension points, as also on the back, connected to the roll cage. When you corner most force comes on the front suspension points.
( Blue one you have, green should be added, with reinforcement, yellow )
22 september 2009 om 21:27 #17525312( green linked to blue I also have but not like you draw… and yellow is reinforced )
Only thing I know for sure is from my old Corsa experience, which had that bar you talk, and this one now without the bar but full welded with rollcage. No comparison possible… I only wished the old corsa handled 25% like this one now.
Yes, I have some pictures of the after painted…
http://img9.imageshack.us/img9/7167/85927323.jpg
http://img225.imageshack.us/img225/3952/39580235.jpg
http://img142.imageshack.us/img142/1302/82653372.jpgI must point out about the rollcage that it is FIA approved and build specific for Corsa B rally cars by British company Safety Devices.
But, maybe you are right… just fitting one and trying it can say for sure if is needed or not in this case.
22 september 2009 om 22:01 #17525313origineel gepost door Akeemking
( green linked to blue I also have but not like you draw… and yellow is reinforced )I cannot see it clear from the picture how you made the replacement for the green line actually:) . But the rest :thumbup , nice work.
22 september 2009 om 22:11 #17525314Originally posted by bbg_gendt
Red line replaces the side green lines…
http://img87.imageshack.us/img87/3107/rollingvidday14io3.jpg:thumbup
22 september 2009 om 22:18 #17525315Okay, got it. But still would prefer the ” bridge “. As when cornering, both coil points, tend to come inside ( exaggerated )
Keep up the good work king:
23 september 2009 om 16:46 #17525316Look who’s taking…. i know a guy named BBG_gendt who used 1mm sheet metal for floar boards without anny strengthening or ridges, then crapped some molded lava on it what he called a weld. So don’t act if u are the stiffnes guru… Chassis is perfect!
Annyway back to the Corsa ! Like your project very much, u got some nice hardware in it!
23 september 2009 om 17:36 #17525317Maybe learn some English first? :sleeping
23 september 2009 om 18:09 #17525318wow nice corsa, nice rollcage indeed :thumbup
23 september 2009 om 18:09 #17525319Whats the problem with my English ? u can’t read it
? :jerry:jerry23 september 2009 om 20:29 #17525320where did you get the blinkers at te front i’m stille looking fot them
very nice corsa i like it
23 september 2009 om 21:12 #17525321origineel gepost door jblfreak
where did you get the blinkers at te front i’m stille looking fot themvery nice corsa i like it
ik dacht dat je die bij de morrette koplampen kreeg omdat daar geen knipperlicht inzit als ik het goed hebt :hmmz
24 september 2009 om 09:56 #17525322Originally posted by Dennis-Corsa-B
where did you get the blinkers at te front i’m stille looking fot themik dacht dat je die bij de morrette koplampen kreeg omdat daar geen knipperlicht inzit als ik het goed hebt :hmmz
Yes Dennis, the blinkers are from Morette kit…
maybe you can contact them and they will sell them separated from the kit.24 september 2009 om 15:52 #17525323:thumbup
24 september 2009 om 16:44 #17525324@ Akeemking :
i got them 2e hand and the where not on the set but still on the corsa because the front bumper
but after the post i got an u2u of someone and he has them for me
but thanks after all
30 september 2009 om 12:19 #17525325Dan jat hij ook nog mijn foto van de corsa b turbo :vertag
Heeft hij zelf geen ombouw fotos van zijn projecten??
Gr.kerni
1 oktober 2009 om 12:40 #1752532601.10.2009 = Stack sensors replacements
Left: Temp -20 to 150c
Right: Wheel speed1 oktober 2009 om 12:44 #17525327Originally posted by KERNI
Dan jat hij ook nog mijn foto van de corsa b turbo :vertagHeeft hij zelf geen ombouw fotos van zijn projecten??
Gr.kerni
I run this through the translator, but did not understand for sure what you ment and want, or if you are talking to me… can you please be more specific so I can reply?
Thanks ;)
1 oktober 2009 om 14:02 #17525328He said:
Then BBG steels my pictures because he hasn’t got any rebuild project pictures of his own projects :vertag
So I think you don’t want to reply :P
( this is almost my best english :D Rolling On Floor Laughing Out Loud ! )
1 oktober 2009 om 16:04 #17525329Thank you freek corsa. :thumbup
1 oktober 2009 om 16:18 #17525330LMFAO and again bbg is trying to be an expert.
anyway, very nice corsa, looked at it best on the porsche wheels imo
1 oktober 2009 om 21:41 #17525331Originally posted by mayhem
anyway, very nice corsa, looked at it best on the porsche wheels imoWell,
the news brake hat on front changed the offset
and the 7j ET55 porsche wheels was positioned out of the arch….…so I sold them.
I tried to buy the 7.5j ones,
which use higher offset (ET65) and might work with camber adjustments and all that
however they are very rare, and I wanted to solve the problem and drive the car.I still look for those here and there…
so in time I might get other set… 7,5j with 9j or 8j with 9j. -
