Forumindex › Forums › Modellen › Corsa › Corsa 1.4 uit 2003 – Boordcomputer doet het niet
- Dit onderwerp bevat 30 reacties, 4 deelnemers, en is laatst geüpdatet op 21 januari 2015om 16:19 door
Ciko66.
14 december 2014 om 19:13 #18264118
@liviu2004 wrote:
Nicht entheiratet means not reset. I think your MID has a security code, but I never played with one, so not 100% sure. NCDC will have another code. Do you know the original radio code from your car?
I have look now in the map that i have ( dont know how to say it in english ‘ onderhouds boek ‘ and all the other papier stuff of the car ), i see i have an old Opel Car Pass..i will scan it and post it here so you can confirm..i think i have the security code..to be continu..
14 december 2014 om 19:16 #18264119Do not post it on internet, it is not wise to publish such info. Car pass is a credit card size and has the security code of the car, of the radio/display, mechanical number of the keys, chassis number.
So, if MID has a code and NCDC has another code, they will not work together. MID has to be reset, also NCDC has to be reset, with their own codes, and then paired together with your original code as per car pass.
BUT, the issue is, on full can units, you cannot reset the screen directly, it works only with a head unit, coded with the same security code. I am not sure how this is done on half can units, I have 0 knowledge on the subject. I never had a MID like that for testing.
14 december 2014 om 19:25 #18264120Ok thats the car pass i have, so i have the security code than.
But what now, u are not sure..what is the best what i can do ?
Go to the dealer, let them make a reset with the right security code i have and all will work ?
Because otherwise i dont no what to do..14 december 2014 om 19:32 #18264121The big question now is, can the MID be reset without radio? I could try with my tech2, but still you are a bit far from me.
http://www.diagnostics.org.uk/help/showthread.php/1643-ncdc-2015″ onclick=”window.open(this.href);return false;
14 december 2014 om 20:13 #18264122I will open an new tread with the new question in NL, i think most people wont write becuase of the english. Maby some one else know it.
Thanks for everything.
21 januari 2015 om 16:19 #18264123Ok beste mensen een update..
Van de week een 2e hands NCDC 2015 weten te scoren welk was afgemeld in de auto met een Op-Com.
Na ontvangst aangelosten bij mij in de auto, werkte de radio. Bij andere opties zoals het plaatsen van een cd en dergelijke constante piepje met radio safe wat natuurlijk normaal is want hij moest met een tech2 of opcom weer geprogrammeerd worden icm de code van mijn auto.
Vandaag naar de Opel dealer te Eindhoven geweest.Helaas wist de aardige man niet dat het kon en riep gelijk dat ik een probleem had omdat mijn oude radio toen het eruit werd gehaald niet afgemeld was. Klein discussie gehad en vertelde hem dat het wel kon en de oude radio er niets mee te maken had. Goed..hij wou het toch proberen na dat ik elke keer ei dat het wel moest kunnen.
Naar de auto gelopen, Tech2 eraan maar mijn code kon er niet in omdat ik een oude software ofzo erin had zitten. Nieuwere erop geprogrammeerd en toen kon de code wel succesvol geprogrammeerd worden. en raad eens..weg piep weg radio safe :D
Raar dat ze het bij de Opel dealer niet wisten hoe/wat, maar al met al een werkende NCDC 2015 in de auto :wors
En dat is Gratis gedaan!
Bedankt aan iedereen voor zijn hulp! Bij deze probleem dus opgelost.
