Hi,
So, I was driving on the interstate for about an hour last weekend and I look at my instrument panel. My temp gauge is pegged, so I pulled over. Antifreeze is seaping out of the radiator cap. Come to find out, the fuse for the radiator fans blew. Replaced it and it seemed fine that weekend.I start driving back home later that weekend and my car starts to get hot again. It doesn’t go all the way up, but it gets close. I turn the AC off and I drive slower (lower RPM’s) and it helps bring the temp down a little, but it is still high.This past weekend, I drive to Atlanta. I still get the hot engine problem. I get my radiator flushed. I drive back to South Carolina yesterday. Still same problem. It gets hot, but not all the way. If it starts getting too hot, I will pull over and let it cool down someSo, the car drives fine around the city and stuff, but once I get on the interstate after about an hour or two, it will start getting hotSo, short version. Radiator fan fuse blows. Replace it. Car now runs hot on long interstate drives. As soon as I pull of the interstate, it cools down quite a bit.So, I have heard it could be something small like a screwed up radiator cap not keeping the pressure or the thermostat could be bad. Also, a blocked radiator or bad water pump could be the culprit. The worst case is that I have a blown head gasketSo, with these symptoms, what does the ARS Collective think is wrong with my car?
Please help.
I didn’t find the right solution from the Internet.
References:-
https://arstechnica.com/civis/viewtopic.php?t=665881
Online Video Production Studio
Thanks!
