Forumindex › Forums › Techniek › Elektrische problemen › Calibra climate control, waar moet welke stekker?
5 september 2012 om 14:47 #17251992
Ik ben aan het kijken waar wat moet komen van de climate control maar kan een aantal stekkers niet meteen thuis brengen. Heb het hele verhaal al op migweb uitgetikt dus hierbij een kopie ervan:
Right I just unpacked the big box with the blower assembly, wiring, control panel and everything minus the fuses and relays… and I find myself wondering where some of the connectors go because the Haynes manual does NOT have the schematic for this. To give some connectors a temporary home I plugged in a spare instrument cluster.
I took pictures of both ends so that people on here can hopefully tell me what they look to belong on, if anyone can dig up the right wiring schematic afterall you will be of EXTREMELY GREAT help to me!
The whole bunch together
First connector that can be found near the fusebox/ignition cylinder
Second
Third/fourth
Fifth
Sixth
Seventh
Eight (look to be relay assemblies, need to know what relays go on here because they did not come with the package, neither did the fuses)
Ninth
Tenth/eleventh
Twelfth
Thirteenth/fourteenth (I will assume that these are supposed to go on each other like this?)
Fifteenth
Sixteenth
Group shot (black/white wire on the leftmost connector goes towards the fusebox)
This is the underpressure hose terminal, need to know where the black hose goes
Can not find the corresponding connector for this socket on the back of the instrument cluster
Another shot of the entire bunch
6 september 2012 om 21:24 #180635121: Richting aanwijzerhendel
2: Lampcontrole module (Check Control)
3: Ruitenwisserhendel
4: Ruitenwisserhendel
5: Remlicht schakelaar ( er hangt nog een stuk schakelaar aan, die eerst eruit wippen )
6: NNB
7: Dagrijlicht Relais (Alleen Scandinavie ivm Verplicht voeren Dimverlichting)
8: Relais in de kleuir van de voet plaatsen
9: aan Motor kabelboom
10: sigaretten aansteker (Rood is constant +)
11: Lampvoet T5 lampje Sigaretten aasteker
12: Sigaretten aansteker (Zwart is geschakelde +)
13: diagnose
14: vanaf diagnose stekker
15: NB
16: NB
17: NB
18: Vacuum voor bediening ECC (Vacuum vanaf voorradbox paravan)
19: Check Control stekker hoort bij de Tellerstekker in de buurt te liggen (indien aanwezigWillem
7 september 2012 om 10:15 #18063513Met andere woorden ik kan er vanuit gaan dat in deze boom geen check control voorbereiding zit want ik kom geen passende stekker tegen die in de buurt van die plek op de tellerklok zit :hmmz
Ik begin er steeds sterker aan te denken om de operatie maar gedeeltelijk uit te voeren en de weinige aanwezige ecc draden gewoon op mijn bestaande draadboom erbij te steken.
Het zou erg helpen als ik wist welk relais op die stekkerstraat waarvan was dan is het wat makkelijker bepalen welke ik nodig heb.
7 september 2012 om 21:46 #18063514Denk dat dat weer los is van de boom, daar ik de tellerstekker ook niet ben tegen gekomen.
De stekker voor de Verlichting Controle is wel aanwezig.
8 september 2012 om 06:03 #18063515Er is wel een losse kleinere boom aanwezig die hoofdzakelijk naar de radio gaat kan de stekker daar nog bij zitten?
8 september 2012 om 14:58 #18063516Zou het niet durven zeggen..
