Forumindex › Forums › Techniek › C20let / z20let(2.0 16v turbo) › breatherbox from x20xev
27 april 2010 om 06:42 #17220495
1. locate the origonal breather elbow from the sump to the rocker cover on the front of the engine.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0948.jpg
2. undo the two factory clamps and remove the elbow.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0949.jpg
3. with the supplied elbow,measure and mark 40mm of straight tube on each end.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0950.jpg
4. cut the tube so you are left with two 40mm straight connectors.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0951.jpg
5. fit one of the tubes to the bottom of the breather box and use one of the supplied clamps to clamp it to the box.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0952.jpg
6. fit the other connector to the rocker cover and use the origonal clamp to secure it to the cover.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0953.jpg
7. slide the other origonal clip onto the black crank vent pipe,and fit the breather box to the top of the vent pipe.then use the clamp to secure it to the vent tube.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0954.jpg
8. with the last supplied clamp,slide it over the connector on the rocker cover.then fit the breather into the tube and retain it with the clamp.
http://i76.photobucket.com/albums/j24/percy69_2006/DSCF0956.jpg
double check everything is tight and the job is done.
27 april 2010 om 06:56 #17662962waarvoor zou dit moeten dienen?
27 april 2010 om 07:10 #17662963Hier weer iets van Percy
http://i151.photobucket.com/albums/s135/sridean/090809_171606.jpg
27 april 2010 om 07:56 #17662964dit zorgt ervoor dat je gasklep en stappen motor minder vervuild raken.
heb het ook in mijn cali x20xev zitten scheelt echt een hoop27 april 2010 om 08:43 #17662965aha, lijkt mij een oli catch tank toch beter :P
maar uhm, is deze niet met het zelfde gemak op een c20ne/ c20xe/ c20let te zetten?
27 april 2010 om 10:36 #17662966wat is percy zijn site?
grtz, martijn
27 april 2010 om 11:55 #17662967Ian Percival is een forumlid van vxr forum in de UK.
Hij heeft geen eigen site… Helaas.
Maar hij wordt overspoeld met aanvragen voor die bout…. En hij doet ook andere zaken. Verkorte inlaat, breatherboxes met slangen, oil restrictor bolts.
27 april 2010 om 14:14 #17662968Percy is gestopt met alle Opel/Vauxhall werkzaamheden vanwege persoonlijke problemen.
27 april 2010 om 15:06 #17662969:swear……
27 april 2010 om 16:31 #17662970Yep , dat is em , heb hem er ook opgezet kost bij de dealer rond de 18 E (ex korting).
part nr 05656098 (Vectra B 2 ltr 16v carterventilatiedoos)Groet Marcel
28 april 2010 om 06:08 #17662971origineel gepost door Mark16v
Percy is gestopt met alle Opel/Vauxhall werkzaamheden vanwege persoonlijke problemen.Euh, waar heb jij die info vandaan??
Erg leuk, dus ik moet het nu bij Regal gaan bestellen…. En ervoor zorgen dat ik mijn geld terug ga krijgen…. Gloeiende:cry
28 april 2010 om 07:10 #17662972origineel gepost door tijgetje57
Gelezen :P
http://www.vxronline.co.uk/forum/showthread.php?t=85548
Mensen die nog een bestelling open hebben staan krijgen hun spullen nog hoor…
29 april 2010 om 16:49 #17662973Maar wat is het voordeel van zo’n breatherbox? Minder vervuiling in je gasklephuis?
29 april 2010 om 17:08 #17662974Vangt de condens op die ontstaat als je motor opwarmt en zorgt ervoor dat deze niet terugvloeit
met de motorolie zodat deze mooi schoon blijft en niet met water residu vervuild kan worden.Groet Marcel.
3 mei 2010 om 20:17 #17662975Oil catch tank werkt net zo goed:D
3 mei 2010 om 20:21 #17662976origineel gepost door zetos
Zeker en is vaak mooier ook , maar ook stukje duurder ,
en ik vond voor zo’n tankje geen geschikt plekkie meer.Groet Marcel.
4 mei 2010 om 06:41 #17662977tja, beide opties dat is dan niet nodig natuurlijk. Of wel??
4 mei 2010 om 14:22 #17662978Zou wel kunnen maar is een beetje “overkill” .
Groet Marcel.
