Forumindex › Forums › Modellen › Adam › *Belangrijk* Terugroepactie Opel Adam
- Dit onderwerp bevat 2 reacties, 2 deelnemers, en is laatst geüpdatet op 30 september 2014om 12:46 door
cocker.
27 september 2014 om 11:12 #17268301
http://www.opel.nl/News/adam_brandpage_btn.aspx
Belangrijk bericht voor Corsa en ADAM rijders.
Belangrijk bericht voor ADAM en Corsa modellen geleverd vanaf mei 2014.
Opel is reaching out to customers of the ADAM and the current Corsa delivered since May 2014. About 8,000 of these vehicles delivered have been manufactured with a steering system part that did not meet specification. To avoid any risk, these cars should not be driven prior to inspection.
As Opel always puts its customers first, and as this condition concerns their safety, the company is taking immediate action. Opel is contacting customers via multiple channels. In case their car is affected, the customer will also be automatically contacted by Opel.
The company became aware of the condition during routine quality controls at the vehicle production plant. The company is not aware of any accident or injury related to this condition.
Customers can find out if their car is affected by following the instructions below. Those who have additional questions can obtain immediate assistance under a hotline number. You can find out below if there is a Call Center number available for your region.
To find out if your ADAM or Corsa is affected, you will have to check the Vehicle Identification Number (VIN Number) and the production code on the intermediate shaft.
How to check whether your vehicle is affected, please follow these instructions:
To do so, please have the Vehicle Identification Number (VIN) of your Vehicle available. You will find the VIN Number on the lower area of your vehicle windscreen or in the registration documents of your vehicle.
VIN Example: (last 8 digits are required)
WOLXXXXXXEXXXXXXX
WOLXXXXXXFXXXXXXX
To identify if your vehicle is affected of this recall, you need to check if your VIN number lies in between the following range:
OPEL ADAM:
VIN Number (last 8 digits) between E6077301 – E6113446
F6000001 – F6006544
OPEL CORSA D:
VIN Number (last 8 digits) between E6071016 – E6118738
E4181031 – E4308122
If your VIN Number is not within this range, your car is not affected.
If your VIN Number is within this range, please continue with the following steps:
Check the production code on the steering intermediate shaft.
If your production code on the steering intermediate shaft is 20E4 or 20K3, your vehicle is affected and should not be driven to avoid any risk.
Where do I find the production code on the intermediate shaft?
Open the driver door of your vehicle.
Ensure your vehicle is positioned safely and the handbrake is engaged fully so that the vehicle is secured safely against roll away.
Ensure the gear of a manual transmission is in neutral or the automatic transmission is in position “P”.
Start the vehicles engine to have the steering power assist enabled.
Look at drivers pedal area.
Look at the area behind the clutch, brake and gas pedal.
Behind the pedals, you will see a metal cardan joint that turns, when you are turning the steering wheel.
Turn the steering wheel, until you can see the relevant codes printed in on the lower joint. (Please see video for reference) link to video
The 4 digit code is printed upside down.
Turn your head in this direction to read them correctly.
Note down the 4 digit code.
Important:
If production code on steering intermediate shaft is 20E4 or 20K3, your vehicle is affected and should not be used/driven to avoid any risk.
In this case, please contact your local dealer.
If the steering column intermediate shaft production code is not 20E4 or 20K3, the vehicle can be safely driven to your next dealer for a final confirmation. Please contact your dealer upfront to make an appointment.
If you feel uncomfortable to do this check yourself, please do not drive your car and contact your Opel dealer as soon as possible.
Safety is our highest priority. Please excuse this inconvenience.
30 september 2014 om 12:45 #18254954Belangrijke veiligheidscontrole.
Controleer uw Corsa of ADAM indien deze geleverd werd sinds mei 2014.Opel roept klanten met een ADAM en Corsa die vanaf mei 2014 zijn afgeleverd op voor een veiligheidscontrole. Er zijn ongeveer 8,000 modellen in Europa geleverd met een stuursysteem onderdeel dat niet aan de specificaties voldoet. Om elk risico te vermijden moet er niet meer in deze auto’s worden gereden totdat ze nader zijn gecontroleerd.
Voor Opel komt de klant altijd op de eerste plaats, daarom wordt er direct actie ondernomen. We proberen klanten via meerdere kanalen te bereiken. En klanten met een auto die tot de risicogroep van deze terugroepactie behoren, worden door Opel zelf benaderd.
Tijdens de dagelijkse kwaliteitscontrole in de fabriek is het probleem geconstateerd. Voor zover bekend zijn er nog geen ongelukken gebeurd die gerelateerd zijn aan dit probleem.
Klanten kunnen zelf een controle uitvoeren om te achterhalen of hun auto tot de risicogroep van deze terugroepactie behoort door het Voertuig Identificatie Nummer ()/ Chassisnummer en de productiecode op de tussenas (intermediate shaft) te controleren. Uiteraard kunt u voor vragen ook contact opnemen met uw Opel dealer.
Hoe kunt u uw auto controleren?
Controleer het Voertuig Identificatie Nummer (VIN nummer)/ Chassisnummer. U kunt het VIN nummer vinden op het onderste gedeelte van de voorruit en/of in uw auto registratiedocumenten.
Voorbeeld VIN nummer (laatste 8 tekens zijn nodig)
Om te achterhalen of uw auto tot de risicogroep van deze terugroepactie behoort, moet het VIN nummer tussen de volgende VIN nummer reeks liggen:
OPEL ADAM:
VIN nummer (laatste 8 tekens) tussen:
E6077301 – F6006544OPEL CORSA huidig model:
E6071016 – E6118738
E4181031 – E4308122Als het VIN nummer van uw auto niet in deze reeks VIN nummers valt, dan behoort uw auto niet tot de risicogroep van deze terugroepactie.
Als het VIN nummer van uw auto wel in deze reeks VIN nummers valt, dan behoort uw auto wel tot de risicogroep van deze terugroepactie. U dient dan de volgende stappen te ondernemen.
Controleer de productiecode op het stuurwiel tussenas.
Als de productiecode 20E4 of 20K3 is, dan behoort uw auto tot de risicogroep van deze terugroepactie en mag u er niet verder mee rijden om elk risico op gevaar te vermijden.
Waar kan ik de productiecode op het stuurwiel tussenas vinden?
Open de deur van de bestuurder en zorg dat uw auto op een veilige plek staat en de handrem is geactiveerd zodat de auto niet kan wegrollen.
Zorg ook dat de versnelling van een handgeschakelde versnellingsbak in neutraal staat of in de “P” –stand in het geval bij een automaat.
Start vervolgens de motor van uw auto om de stuurkracht te activeren.
Controleer de pedalen bij de bestuurder.Kijk naar het gebied achter de koppeling, rem en gaspedaal.
Achter de pedalen ziet u een metalen cardankoppeling dat draait als u het stuurwiel draait.
Draai het stuurwiel totdat u een 4-cijferige code kunt zien.
De 4-cijferige code staat ondersteboven afgedrukt.Draai uw hoofd om de code correct te kunnen lezen en noteer de 4-cijferige code.
Belangrijk:
Als de productiecode op het stuurwiel 20E4 of 20K3 is, dan behoort uw auto tot de risicogroep van deze terugroepactie en mag u er niet verder mee rijden om elk risico op gevaar te vermijden. Neem ook direct contact op met uw Opel dealer.
Als de productiecode op het stuurwiel niet 20E4 of 20K3 is, dan behoort uw auto niet tot de risicogroep van deze terugroepactie en kunt u er mee naar uw Opel dealer rijden voor een definitieve bevestiging. Neem vooraf contact op met uw Opel dealer voor een afspraak.
Als u zich niet zeker voelt om deze controle zelf uit te voeren, dan raden we aan om niet meer met uw auto te rijden en zo spoedig mogelijk contact op te nemen met uw Opel dealer.
Zoek hier uw Opel dealer.
Bij eventuele vragen kunt u contact opnemen met Opel Customer Assistance Center. In het geval dat er geen Customer Center contact beschikbaar is voor uw regio, neem dan contact op met uw plaatselijke Opel dealer.
Telefoonnummer voor België: 03/450.63.29 op werkdagen van 09.00 tot 17.30.
Veiligheid is onze hoogste
30 september 2014 om 12:46 #18254955Heb het bij die van mijn vrouw nagekeken en gelukkig heeft hij andere code op de stuurkolom!!
