aanhaalmomenten
  • #17240976
    drakos
      6 December 2010
      voor de liefhebber, zag het verder nergens staan
      is een directe copy uit tis voor de X25XE, Y26SE, X30XE, Y32SE
      Adapter, fuel distributor pipe to intake bridge
      8
      Adapter, fuel distributor pipe to fuel distributor pipe
      15
      Starter to cylinder block
      40
      Intake bridge to intake flange
      20
      Intake flange to cylinder head
      20
      Drive disc / flywheel to crankshaft
      65 + 30° + 15° (1) 2)
      Exhaust manifold to cylinder head
      20 (3)
      Oil filter housing cover to oil filter housing
      25
      Heat exchanger cover to heat exchanger
      30
      Heat exchanger cover to cylinder block
      20
      DIS ignition module to member
      8
      Torsional vibration damper to toothed belt drive gear
      20
      Throttle body to intake plenum
      8
      Pressure line to power steering pump
      28
      Accelerator pedal module to bulkhead
      20
      Link rod to stabiliser
      65 (3)
      Alternator to cylinder block and oil pump
      35
      Transmission to cylinder block (M8)
      20
      Transmission to cylinder block (M12)
      60
      Transmission holder to underbody
      45 (4)
      Threaded sleeves to crankshaft bearing bridge
      8
      Base plate, toothed belt tension roller and toothed belt guide roller to cylinder head
      40
      Auxiliary aggregate(s) support to cylinder block
      35
      Idler bracket to body
      55 + 75° + 15° (1)
      Rear toothed belt cover to cylinder head and oil pump (M6)
      8
      Rear toothed belt cover to cylinder head and oil pump (M8)
      10
      Crankshaft pulse pick-up in cylinder block
      8
      Crankshaft pulse pick-up disc to crankshaft
      15 (1)
      Refrigerant lines to compressor
      40
      Ribbed V-belt pulley to coolant pump
      8 + 30° + 30° (1)
      Ribbed V-belt pulley to power steering pump
      20 + 30° + 15° (1)
      Ribbed v-belt tension roller to cylinder head
      35
      Knock sensor to cylinder block
      20
      Fuel lines to adapter, fuel distributor pipe
      15
      Fuel distributor pipe to intake bridge
      8
      Coolant bridge to cylinder head
      30 (5)
      Coolant intake pipe to exhaust manifold
      8
      Coolant intake pipe to cylinder block
      20
      Coolant pump to cylinder block
      25
      Coolant pipe and engine transport shackle to cylinder head
      25
      Ball joint to steering knuckle
      100 (3)
      Crankshaft bearing bridge to cylinder block
      20
      Crankshaft bearing cap and crankshaft bearing bridge to cylinder block cylinder block
      50 + 60° + 15° (1)
      Oxygen sensor in front exhaust pipe
      30 (6)
      Steering arm to steering shaft
      160 (3)
      Solenoid valve for intake plenum switchover valve to switchover valve
      8
      Secondary air metal pipe to exhaust manifold
      20
      Engine damping block to engine bracket
      40
      Engine vent housing to cylinder block
      8
      Engine damping block to front axle body
      55
      Engine bracket to cylinder block
      40
      Engine bracket, engine damping block to cylinder block
      60
      Camshaft bearing caps to cylinder head
      8
      Camshaft sprocket to camshaft
      50 + 60° + 15° (1)
      Camshaft sensor to camshaft bearing cap
      8
      Oil drain bolt to oil pan (inner Torx bolt)
      10
      Oil drain bolt to oil pan (hex bolt)
      55
      Oil pressure switch to oil pump
      40
      Oil filter to cylinder block
      15
      Oil filter casing to cylinder block
      45
      Oil lines (banjo bolt) to heat exchanger
      30 + 30° + 15° (1)
      Oil lines to cylinder block
      30
      Oil pump to cylinder block (up to MY ’99) – M6 bolt
      8 + 10 (7) 8 )
      Oil pump to cylinder block (as of MY ’99) – M8 bolt
      12 + 20 (8) 9)
      Oil intake pipe to oil pump and to crankshaft bearing bridge
      8
      Oil baffle plate to crankshaft bearing bridge
      8
      Oil feed and return lines to cylinder block
      30
      Upper part of oil pan to transmission housing – M8 bolt
      20
      Upper part of oil pan to transmission housing – M10 bolt
      40
      Upper part of oil pan housing to cylinder block and oil pump
      15
      Lower part of oil pan housing to upper part of oil pan housing
      8 + 30° (1)
      Con-rod bearing cap to con-rod
      35 + 45° + 15° (1)
      Wheel to wheel hub
      110
      Intake plenum to intake bridge
      8
      Shift outrigger to transmission
      20
      Hose clamps for air intake hose
      3.5
      Clamp, fuel pressure regulator to fuel distributor pipe
      5
      Vibration damper to front axle body bracket and to engine bracket
      40
      Coolant temperature sensor in coolant bridge
      18
      Tie rod to steering knuckle
      60 (3)
      Support to exhaust gas recirculation valve adapter
      20
      Tank vent valve to engine vent housing
      8
      Temperature sensor to coolant bridge
      18
      Thermostat housing to cylinder block
      20
      Union nut to screw-on connection, exhaust gas recirculation valve adapter
      25 (10)
      Intake plenum switchover valve to intake plenum
      8
      Brake servo vacuum line to intake plenum
      20
      AC compressor to auxiliary aggregates support
      35
      Oil pressure regulating valve screw plug to oil pump
      60
      Closure bolt, safety valve to oil pump
      30
      Front axle body to body (front)
      65 + 30° + 15° (1)
      Front axle body to side member (centre)
      150 + 30° + 15° (1)
      Front axle body to side member (rear)
      130 + 30° + 15° (1)
      Front toothed belt cover to rear toothed belt cover
      8
      Front exhaust pipe to exhaust manifold
      30
      Pre-volume chamber to fastening points
      2.5
      Exhaust gas recirculation corrugated pipe to exhaust gas recirculation valve adapter and exhaust manifold
      25
      Toothed belt tension roller to bracket
      20
      Toothed belt guide roller to cylinder block
      40
      Toothed belt guide roller to toothed belt tension roller bracket
      40
      Toothed belt guide roller to oil pump
      40
      Toothed belt drive gear to crankshaft
      250 + 45° + 15° (1)
      Spark plugs to cylinder head
      25
      Cylinder head to cylinder block
      25 + 270° + 15° (1) 11)12)
      1) Use new bolts.
      2) Insert bolts with bolt locking compound (red).
      3) Use new nuts.
      4) Clean thread and insert bolts with bolt locking compound (red).
      5) Use new copper seal rings.
      6) When re-using oxygen sensor, coat thread with special grease (black).
      7) Tightening to 10 Nm is performed after 10 minutes for the old version (without additional bore) and only after assembly of the complete toothed belt drive for the newer version.
      8 ) Clean thread of fastening bolts and insert with bolt locking compound (red).
      9) Tightening to 20 Nm is only performed after installation of the lower alternator fastening bolt.
      10) Before assembly, coat thread of screw-on port with assembly paste (white).
      11) In three stages of 90° each.
      12) Retightening not required.
