Aanhaalkoppel Astra H turbo
Forumindex Forums Modellen Astra Aanhaalkoppel Astra H turbo
  • #18402522
    CBA
      11 June 2017
      Heeft iemand de aanhaalkoppels voor een Astra H Diesel 1.9 CDTI van 2005 ?
      het betreft de gegevens voor spruitstuk / Kop
      #18402607
      Haasje17
        8 September 2009
        Cylinder head
        Renew bolts Yes
        Stage 1 Tighten 20 Nm
        Stage 2 Tighten 65 Nm
        Stage 3 Tighten 90°
        Stage 4 Tighten 90°
        Stage 5 Tighten 90°
        Other tightening torques
        Big end bearings Renew bolts/nuts Yes
        Big end bearings Stage 1 25 Nm
        Big end bearings Stage 2 60°
        Oil pump to cylinder block 9 Nm
        Sump bolts 9 Nm M8=25 Nm
        Sump drain bolt 20 Nm
        Flywheel/driveplate 160 Nm
        Clutch to flywheel 28 Nm
        Crankshaft pulley/damper centre bolt 340 Nm
        Camshaft sprocket/gear 120 Nm
        Camshaft carrier/cap 25 Nm
        Camshaft/rocker cover 10 Nm
        Inlet manifold to cylinder head 25 Nm
        Exhaust manifold to cylinder head 25 Nm
        Water pump 25 Nm
        Injector/clamp 25 Nm
        Injector pipe unions 25 Nm M14=23 Nm
        Glow plugs 8 Nm
        Crankshaft position (CKP) sensor/engine speed (RPM) sensor 9 Nm
        Camshaft position (CMP) sensor 7 Nm
        Engine coolant temperature (ECT) sensor 20 Nm
        Engine oil pressure switch 25 Nm
        Oil filter 25 Nm
        Front hub
        Steering wheel 30 Nm
        Steering track rod end 60 Nm
        Brake disc to hub Front 7 Nm
        Brake caliper to carrier Front 28 Nm
        Brake caliper carrier to hub Front 100 Nm
        Brake disc to hub Rear 4 Nm
        Brake caliper to carrier Rear 25 Nm
        Brake caliper carrier to hub Rear 100 Nm
        Road wheels 110 Nm
        #18402612
        CBA
          11 June 2017
          Grandioos, hartelijk bedankt, kunnen we hem afmaken
