welke water pomp cors
Best is to buy based on the original GM number. If you give me your serial number of the car (VIN), I can look it up in Electronic Parts Catalogue (EPC4). Although I will not give any warranty (for info, on my car it worked ok so far).
@liviu2004 wrote:Best is to buy based on the original GM number. If you give me your serial number of the car (VIN), I can look it up in Electronic Parts Catalogue (EPC4). Although I will not give any warranty (for info, on my car it worked ok so far).
Do you mean this ? 21-jt-zh
That is good as well. Your car serial is W0L0XCF0824281046.
I have also 2 codes:
- GM 93182029, pump assembly, PIERBURG, no longer supplied, replaced by GM 93189693
- GM 95507589, pump assembly, SHW/AIRTEX.
I think the difference lies with the manufacturer. I cannot advise you further. You need to find out which maker you have on board.
