vliegwiel c20ne
Wat wil je precies bereiken?
Clutch Pressure Plate
Performance
Engine number to : 14330715
Diameter [mm]: 215
Reinforced Version:
Parameter: MF215
Remove and install clutch only with assembly rin
Clutch Disc
Performance
Engine number from : 14608701
Hub Profile: 18,3x20,4-24N
Number of Teeth: 24
Parameter: 210TB
Diameter [mm]: 210
max. transmittable engine torque: 250 Nm
torsion damper plate with organic facings
Clutch Disc
Performance
Number of Teeth: 24
Parameter: 210TS
Diameter [mm]: 210
torsion damper sintered plate
