Storings Code Lijst?
12 Diagnosis initiation/separator (indicates beginning/end of fault code list)
13 Oxygen sensor - open circuit
14 Coolant temperature sensor - voltage low
15 Coolant temperature sensor - voltage high
16 Knock signal circuit - no voltage change
17 Knock signal circuit 2 - no voltage change (V6 models only)
18 Knock control module (ECU)
19 Incorrect RPM signal (Crankshaft sensor - incorrect signal)
21 Throttle position sensor - voltage high
22 Throttle position sensor - voltage low
23 Knock sensor - out of range
24 Speed sensor (MPH)
25 Injector 1 - voltage high
26 Injector 2 - voltage high
27 Injector 3 - voltage high
28 Injector 4 - voltage high
29 Injector 5 - voltage high/ Fuel pump relay voltage low (non-V6 models)
30 Injector 6 - voltage high (V6 models only)
31 No engine RPM signal (engine not running, or no Crankshaft sensor signal)
32 Fuel pump relay - voltage high
33 MAP sensor - voltage high
34 MAP sensor - voltage low
35 Idle air control valve stepper motor (no idle speed control)
38 Oxygen sensor - voltage low (weak mixture)
39 Oxygen sensor - voltage high (rich mixture)
41 1 gear indent switch - voltage low
42 1 gear indent switch - voltage high
43 EGR system
44 Oxygen circuit - voltage low (weak mixture)
45 Oxygen circuit - voltage high (rich mixture)
47 Linear EGR position
48 Battery - voltage low
49 Battery - voltage high
51 ECU memory failure
52 Check engine light - voltage high
53 Fuel pump relay - voltage low
54 Fuel pump relay - voltage high
55 ECU faulty
56 Idle air control valve - voltage low/high
57 Idle air control valve - voltage high/low
61 Fuel tank vent valve - voltage low
62 Fuel tank vent valve - voltage high
63 EST line coil cylinders 2 & 3 - voltage low
64 EST line coil cylinders 1 & 4 - voltage low
65 Idle CO potentiometer - voltage low
66 Idle CO potentiometer - voltage high
67 Idle position switch - voltage low (idle position switch not opening)
69 Intake air temperature sensor - voltage low
71 Intake air temperature sensor - voltage high
72 Full position switch - voltage high
73 Air flow sensor - voltage low
74 Air flow sensor -voltage high
75 Torque control - voltage low
76 Torque control - continuous
79 Full load inhibitor - voltage low (traction control signal)
81 Injector valve 1 - voltage low
82 Injector valve 2 - voltage low
83 Injector valve 3 - voltage low
84 Injector valve 4 - voltage low
85 Injector valve 5 - voltage low (V6 models only)
86 Injector valve 6 - voltage low (V6 models only)
87 A/C cut-off relay - voltage low
88 A/C cut-off relay - voltage high
92 Camshaft sensor failure
93 Hall sensor - voltage low
94 Hall sensor - voltage high
95 Hot start valve - voltage low
96 Hot start valve - voltage high
97 Ignition/Injection cut off - voltage high (traction control signal)
113 Boost control out of range (turbo models only)
114 Boost pressure (idle) above upper limit (turbo models only)
115 Boost pressure (full) below upper limit (turbo models only)
116 Boost pressure (full above upper limit (turbo models only)
117 Wastegate valve - voltage low (turbo models only)
118 Wastegate valve - voltage high (turbo models only)
Jeroen
43 EGR system
55 ECU faulty
Jeroen
