Hello.
I have an Opel Vectra gts 2.2 benzine Z22se.
I was told by the opel dealer that I need to change the kettingset, because the engine is vibrating heavily and based on a readout from the computer.
However the engine is vibrating only very slightly. There are no noises and any ticking sounds when the engine is on and running. I have been to another garage which did a readout and said there were no reports of problems.
They did advise to change the kettingset (alleen voor de nokkenas) but it was not urgent.
Can you advise what I should do? Did anyone else have this problem before. It is quite expensive to have the kettingset changed so please advise.
Thank you in advance.
P.S You can also reply in dutch.
