aanhaalmomenten
drakos
Komt hier geregeld
voor de liefhebber, zag het verder nergens staan
is een directe copy uit tis voor de X25XE, Y26SE, X30XE, Y32SE
Adapter, fuel distributor pipe to intake bridge
8
Adapter, fuel distributor pipe to fuel distributor pipe
15
Starter to cylinder block
40
Intake bridge to intake flange
20
Intake flange to cylinder head
20
Drive disc / flywheel to crankshaft
65 + 30° + 15° (1) 2)
Exhaust manifold to cylinder head
20 (3)
Oil filter housing cover to oil filter housing
25
Heat exchanger cover to heat exchanger
30
Heat exchanger cover to cylinder block
20
DIS ignition module to member
8
Torsional vibration damper to toothed belt drive gear
20
Throttle body to intake plenum
8
Pressure line to power steering pump
28
Accelerator pedal module to bulkhead
20
Link rod to stabiliser
65 (3)
Alternator to cylinder block and oil pump
35
Transmission to cylinder block (M8)
20
Transmission to cylinder block (M12)
60
Transmission holder to underbody
45 (4)
Threaded sleeves to crankshaft bearing bridge
8
Base plate, toothed belt tension roller and toothed belt guide roller to cylinder head
40
Auxiliary aggregate(s) support to cylinder block
35
Idler bracket to body
55 + 75° + 15° (1)
Rear toothed belt cover to cylinder head and oil pump (M6)
8
Rear toothed belt cover to cylinder head and oil pump (M8)
10
Crankshaft pulse pick-up in cylinder block
8
Crankshaft pulse pick-up disc to crankshaft
15 (1)
Refrigerant lines to compressor
40
Ribbed V-belt pulley to coolant pump
8 + 30° + 30° (1)
Ribbed V-belt pulley to power steering pump
20 + 30° + 15° (1)
Ribbed v-belt tension roller to cylinder head
35
Knock sensor to cylinder block
20
Fuel lines to adapter, fuel distributor pipe
15
Fuel distributor pipe to intake bridge
8
Coolant bridge to cylinder head
30 (5)
Coolant intake pipe to exhaust manifold
8
Coolant intake pipe to cylinder block
20
Coolant pump to cylinder block
25
Coolant pipe and engine transport shackle to cylinder head
25
Ball joint to steering knuckle
100 (3)
Crankshaft bearing bridge to cylinder block
20
Crankshaft bearing cap and crankshaft bearing bridge to cylinder block cylinder block
50 + 60° + 15° (1)
Oxygen sensor in front exhaust pipe
30 (6)
Steering arm to steering shaft
160 (3)
Solenoid valve for intake plenum switchover valve to switchover valve
8
Secondary air metal pipe to exhaust manifold
20
Engine damping block to engine bracket
40
Engine vent housing to cylinder block
8
Engine damping block to front axle body
55
Engine bracket to cylinder block
40
Engine bracket, engine damping block to cylinder block
60
Camshaft bearing caps to cylinder head
8
Camshaft sprocket to camshaft
50 + 60° + 15° (1)
Camshaft sensor to camshaft bearing cap
8
Oil drain bolt to oil pan (inner Torx bolt)
10
Oil drain bolt to oil pan (hex bolt)
55
Oil pressure switch to oil pump
40
Oil filter to cylinder block
15
Oil filter casing to cylinder block
45
Oil lines (banjo bolt) to heat exchanger
30 + 30° + 15° (1)
Oil lines to cylinder block
30
Oil pump to cylinder block (up to MY '99) – M6 bolt
8 + 10 (7) 8 )
Oil pump to cylinder block (as of MY '99) – M8 bolt
12 + 20 (8) 9)
Oil intake pipe to oil pump and to crankshaft bearing bridge
8
Oil baffle plate to crankshaft bearing bridge
8
Oil feed and return lines to cylinder block
30
Upper part of oil pan to transmission housing – M8 bolt
20
Upper part of oil pan to transmission housing – M10 bolt
40
Upper part of oil pan housing to cylinder block and oil pump
15
Lower part of oil pan housing to upper part of oil pan housing
8 + 30° (1)
Con-rod bearing cap to con-rod
35 + 45° + 15° (1)
Wheel to wheel hub
110
Intake plenum to intake bridge
8
Shift outrigger to transmission
20
Hose clamps for air intake hose
3.5
Clamp, fuel pressure regulator to fuel distributor pipe
5
Vibration damper to front axle body bracket and to engine bracket
40
Coolant temperature sensor in coolant bridge
18
Tie rod to steering knuckle
60 (3)
Support to exhaust gas recirculation valve adapter
20
Tank vent valve to engine vent housing
8
Temperature sensor to coolant bridge
18
Thermostat housing to cylinder block
20
Union nut to screw-on connection, exhaust gas recirculation valve adapter
25 (10)
Intake plenum switchover valve to intake plenum
8
Brake servo vacuum line to intake plenum
20
AC compressor to auxiliary aggregates support
35
Oil pressure regulating valve screw plug to oil pump
60
Closure bolt, safety valve to oil pump
30
Front axle body to body (front)
65 + 30° + 15° (1)
Front axle body to side member (centre)
150 + 30° + 15° (1)
Front axle body to side member (rear)
130 + 30° + 15° (1)
Front toothed belt cover to rear toothed belt cover
8
Front exhaust pipe to exhaust manifold
30
Pre-volume chamber to fastening points
2.5
Exhaust gas recirculation corrugated pipe to exhaust gas recirculation valve adapter and exhaust manifold
25
Toothed belt tension roller to bracket
20
Toothed belt guide roller to cylinder block
40
Toothed belt guide roller to toothed belt tension roller bracket
40
Toothed belt guide roller to oil pump
40
Toothed belt drive gear to crankshaft
250 + 45° + 15° (1)
Spark plugs to cylinder head
25
Cylinder head to cylinder block
25 + 270° + 15° (1) 11)12)
1) Use new bolts.
2) Insert bolts with bolt locking compound (red).
3) Use new nuts.
4) Clean thread and insert bolts with bolt locking compound (red).
5) Use new copper seal rings.
6) When re-using oxygen sensor, coat thread with special grease (black).
7) Tightening to 10 Nm is performed after 10 minutes for the old version (without additional bore) and only after assembly of the complete toothed belt drive for the newer version.
8 ) Clean thread of fastening bolts and insert with bolt locking compound (red).
9) Tightening to 20 Nm is only performed after installation of the lower alternator fastening bolt.
10) Before assembly, coat thread of screw-on port with assembly paste (white).
11) In three stages of 90° each.
12) Retightening not required.
