vliegwiel c20ne
Forumindex Forums Techniek C20ne/seh (2.0 8v) vliegwiel c20ne
  • #18341776
    lonspeed
      3 April 2012
      weet iemand welke afmeting koppelinsplaat er op een c20ne vliegwiel past?
      #18350710
      Corsa_GSi
        Wat wil je precies bereiken?
        Clutch Pressure Plate
        Performance
        Engine number to : 14330715
        Diameter [mm]: 215
        Reinforced Version:
        Parameter: MF215
        Remove and install clutch only with assembly rin
        Clutch Disc
        Performance
        Engine number from : 14608701
        Hub Profile: 18,3×20,4-24N
        Number of Teeth: 24
        Parameter: 210TB
        Diameter [mm]: 210
        max. transmittable engine torque: 250 Nm
        torsion damper plate with organic facings
        Clutch Disc
        Performance
        Number of Teeth: 24
        Parameter: 210TS
        Diameter [mm]: 210
        torsion damper sintered plate
